What is actually inside the Mybook box?. Is it a normal SATA drive? If so is the remapping of 512>4K sector on the harddrive electronics or is it in the circuit board that contains the USB interface and power supply?.
Basic question, if I remove the harddrive from the case can I plug it into my MBoard SATA connectors and will it work properly?
I tried looking up detailed specs on the device but they don’t show much except for detailed performance numbers.
tks
Don
