Can anyone help with this? I keep getting this when I try to download the required software for the WD Elements My Book to work on my PC. Thanks!
WD FAT32 Formatter has gone under EOL and recommend to follow the steps provided in below article if you want to format your WD Elements drive.
Moreover, you can also use Windows Data Lifeguard Diagnostic tool to erase your drive permanently and after this, you won’t be able to recover any data if you performed .
