when i cut my mp player on its on music file is already open but its a video thats called waz. mine to remember is on and it will not let me get 2 my music n play my music. what do i do?
This happens when you shut off the fuze while it’s still playing a video. To stop this from happening again, you need to pause the video, and press the home button to bring it back to the main screen. Then shut off the fuze.
I get this exact fault. I have tried your fix but it doesn’t work.
Specifically, I turn the fuze on, and pick a song. The fuze then resets, and displays the splash screen. Then, this file waz. mine to remember is “playing”.
That is, it is on the screen with a play symbol, but no video or audio. I can get to the home menu and use the controls, but when I select a song, it goes back to waz. mine to remember and freezes completely, although I can get it to turn off after 10 seconds.
I tried your fix, it gives me a few different results, but always similar to the above.
I have also tried factory reset, this doesn’t seem to do anything, althogh all settings were default anyway.
Admittedly I am somewhere without my link cable, so I haven’t tried that yet.
Any suggestions?
My girlfriend’s player had this same “Waz.mine to remember” video stuck on the display. I plugged in the USB cable from the computer to the player. On my computer, I opened the player as a device, then I went to the Video directory and deleted the “Waz.mine to remember” video. Then I unplugged the player, shut it off, turned it on, and it was fine.
