My Sansa wont turn on!!!
I left for vacation for two months and i forgot my sansa and when i get back it wont turn on…i tried connecting it to the computer but that didn’t work, the blue circle thing turned on for awhile so i thought it was just the screen, but i tried moving the circle thing and the blue thing turned off…please help me!!!
reset! slide up the power switch and hold it for about 15~30 seconds (even though it looks like its not helping) then try to turn it back on… this works 99.9% (i’m reserving the .1% incase this fails) :stuck_out_tongue:
In addition to that you can also force MSC your player and conenct it to your computer and to do the force MSC kindly do the following;
Sansa Fuze
  1. Turn device OFF.
  2. Slide the Hold switch down to Lock (orange color showing).
  3. Press and hold the left button ( |<< ) while connecting the device to the PC.
Hope this works. :wink:
