my sansa modeel:e260 somehow screwed up how do i put it i...
my sansa modeel:e260 somehow screwed up how do i put it iinto recovery mode?:robotsad:
Turn the player off by holding the menu/power button for about 30 seconds, put the hold switch on, hold the record button, and then plug into the computer.
You should then be able to reload firmware by using the updater.
