my sansa e260 4GB in not working,as i on only blue ring lits up and nothing on the screen except black…i can’t put it in recovery mode also…what can i do to make it work normal??
You will need to remove and replace the battery first. Then try placing it in recovery mode. This worked for me. However, I can not find the files to install now that I’m there… The post I got the instructions from had a bad link.
Good luck
Poppa Smurff
i have added i2c.bin a binary file in the recovery mode.after this it stopped recognising in recovery mode also so,what can i do furthur?
