irock
1
When I’m done formatting my clip+ , does that mean I have to reload all of my songs onto my mp3 again?
When formatting, do I have to stick to one PC that allows me to add my songs and not show up “._”
I used a MAC to transfer my songs before already; but I decided to format it. Do I have to transfer my songs using one PC?
Can I still use a MAC to transfer songs after formatting my Sansa?
Yes.
Use Kopymac (Google it) to transfer your files using a Mac to avoid the ._ prefix. Make sure your player is set to MSC mode, not MTP or Auto Defect.
Yes.
Or use a PC if you have one available to assure the fewest problems and/or issues.
