I bought it 6 months ago. First symptom: the “move ahead” button wasn’t always working. Next symptom: music started freezing. Next symptom: the display turned to hash. This all happened within the past 4 days.
I plugged the clip into my computer(via USB) and the computer doesn’t see any content on it(in fact, there’;s about a full gig on it). Now the thing doesn’t work at all.
Suggestions? Another clue–this began happening after I searched for firmware updates, although no updates were found.
Format it using the computer. Push the power button to the down position. Hold the middle button while connecting to the pc. Keep holding it until the player is recognized. On the pc, find the Clip, right clip on it, and choose format. Next download the firmware and install it manually. If the firmware on the player is corrupted, reloading the same firmware version you have will solve the problem. After this, turn on the player and format it again using the player’s menu. After this, you can reload the music.
