My Sansa Clip hangs while playing and charging......
Can anybody help me what to do when Sansa hangs???
Use the soft reset function.  Slide the power switch to the ON position, ans hold it there for 10-15 seconds.  Release the switch, then power up as usual.
µsansa
Thanks, it works!! I was worried as my Sansa got hung today, but following your suggestions, I went for a soft reset and it worked fine :slight_smile:
