I use my Sansa Clip when I work out at the YMCA. I used it last night and it worked fine then. This morning when I went to the Y, it did not work at all. Once I got home, I plugged it into my computer. It still does not work. Why is it not working and can I get it fixed?
How about some Sansa magic?
Slide the power switch up to the ON position, and hold it there for 10-15 seconds. If you have sensitive earbuds on, you can hear a soft “click” as the device resets. This is the soft reset function. Your Clip should restart normally after the reset. Try powering up as usual.
µsansa
Thanks so much microsansa
That worked!!! You made me happy and I thank you ![]()
Thank you sooooo much. It’s working. Have an awesome day
