My SanDisk do not turn on.
Hello everyone,my first post here.
Hope someone can help me .
Only charging . If desconect from charger lights go off and impossible to turn on. What can i do ? I use it for races …:face_with_raised_eyebrow:
Hi @Luiz,
(Get Support for Your SSDs and Flash Products | Sandisk)
If not, contact Sandisk Technical Support for assistance.
(Contact Support | Sandisk)
Hi…Thank you. I already contacted support …
That sounds like a battery issue, not Windows. If it dies immediately when you unplug the charger, the battery is likely disconnected, failed, or no longer holding a charge. Try a 30 to 40 second power button reset, then check whether the battery is detected in the device’s BIOS or diagnostics. If it still only works on the charger, the battery or its connection likely needs replacing.
