my sandisk cannot read in my laptop but previously this sandisk is running.
what will i do to fix my sandisk 16gb? i’ve inserted many times but not recognized my laptop. i’ve try my another flashdrive, the flash drive is running. please help me for my sandisk usb flash drive. thanks
if your flash drive is not recognized there is not much you can do. Usually it is either controller that failed or connector is loose.
I know for a fact that sometimes if the usb stick is not recognized flexing it up or down, and holding it in that possition may give you temp access to the volume. That can help you copy files off of it. Also applying hot solder to existing 4 pins of the usb connector can help.
Hp products have been used worldwide and have gained huge popularity with its cutting edge technology and amazing features. Get immediate solution by dialing our HP customer support number​
