error code 10 means the device could not start. probably due to a driver issue. make sure you have at least WMP 10 and service pack 2 installed. i would recoment WMP11 as it has much better mtp support.
you could always switch to msc mode which will probably resolve the issue as well.
to change usb modes in the clips menu go to settings>usb mode> and select msc
The above as to switching to MSC mode assumes that you have firmware version 18 or higher. If you don’t, you should put it on (version 20 just came out yesterday–recommended) and then follow the above and switch to MSC mode and see if that helps/works for you.
thanks Miikerman i didnt think of that. here is the lates clip firmware if you do not have it installed.
