Hello
My Passport Ultra - external drive - partition can not be recognised - no data available logs in attach
please help
thanks
LOGS details
17.6.2021. 17:18:41 Severity=INFORMATION Message=My Passport Ultra: 0820WX81AA3M2888 F/W: 1007
@Dodo, There could be a few reasons why the drive partition is not recognized. The drive itself could have failed, the partition on the drive may be damaged, the data cable may no longer be good, or the drive may no longer be getting enough power to fully spin up.
In order to understand the health of the drive, we would request you to install and WD Drive Utilities and run the test:
Link: Error
Yes there is a possible way to recover your data from corrupted or lost partition drive. You can try the below 4 different solutions to resolve your issue:
Solution 1: Run SFC Scan
Sometimes, corrupted or missing system files can cause hard drive partition or volume to disappear. The System File Checker (SFC) tool can be used to scan and repair missing or corrupted system files. You can run SFC scan on your system by following these steps:
Press ‘ Windows+Q ’ to open search bar and type cmd .
Press ‘ CTRL+SHIFT+ENTER ’ to run cmd as Administrator or right-click on cmd and select “ Run as Administrator ”.
Next, type sfc /scannow to run the SFC scan.
If SFC scan finds any problem with system files, it can ask for Windows installation DVD or media to repair corrupt and damaged system files.
Solution 2: Run ‘Chkdsk’ command
Chkdsk is an inbuilt disk error checking and repair utility in Windows. Chkdsk scans the hard drive partition for internal errors and fixes them simultaneously. The ‘Chkdsk’ utility repairs the file system errors that corrupts the hard drive partitions and make them disappear. To repair damaged hard drive partition with Chkdsk, follow these steps:
Type cmd in Windows search box and Press ctrl + shift + enter.
Click ‘ Yes ’ to grant Admin access. A cmd Window appears.
Type command chkdsk X: /f where X is the hard drive partition letter. Alternatively, you can type chkdsk X: /F /X /R for the rigorous scanning process.
Hit Enter and wait until ‘Chkdsk’ utility repairs the disk errors.
Solution 3: Restore the Missing Hard drive Space using Disk Management
Disk management is a tool that is used to create and manage hard drive partitions in Windows. You can use Disk management tool to restore the missing hard drive space by following these steps:
Press Windows + R . In the box, type diskmgmt.msc and press Enter . Disk Management window appears.
Right-click on the unallocated hard disk partition and choose New Simple volume. New Simple volume wizard opens.
Follow the wizard: specify the volume size, assign a drive letter, and choose NTFS from File System drop-down. Click Next to confirm followed by the Finish button.
Solution 4: Use Data Recovery Software
You can try using Stellar Data Recovery Professional software to recover your lost or deleted system files as it is one of the best data recovery software that enables the user to recover data from corrupted or accidentally formatted drive & lost partitions of the drive.
