Hello and thank you for the help.
My passport studio has decided to no longer mount on my MacBook Pro or my iMac. I have followed a few ‘fixes’ that have not worked such as attempting to force mount (not sure I typed the command correctly, so thats an issue) Also, went into utilities and see the EHD but won’t repair. Tells me to backup as many files as possible and reformat but how do you backup something that won’t mount? Ugh!!! I’m not a computer expert so any help, explained in simple terms would be helpful.
Thank you for the help.
Kelly
