Ive purchased a My Passport Studio.
I have set my label etc, and used VCD manager to hide the Smartware virtual CD etc.
How do I get the label to display the space used/remaining on the drive?? Its disappeared for some reason?
Here is what I found:
You need to install the WD Smartware software from the Virtual CD.
It will sync with the drive and the Label will show the space used/remaining on the drive.
After that you can uninstall the WD Smartware.
