Hi there,
I purchased a WD My Passport 4tb,but i ran into a problem the hard drive keeps sending me a message saying,slot B is missing please replace slot B.Called the company they couldn’t help me.Those anyone out there has any idea please share it,thanks.
I haven’t seen this case before.
Where did you purchase the drive?
Are you able to copy files to the drive?
I got it from BestBuy,and yes i’m able to copy files.My problem stems from,when i first connet the hard rive to my Mac Pro that’s when the warning shows up telling me that slot B is missing and that i should replace it.I have spoken to Western Digital, but they did nothin,they asked me to run the usual tests,and i did and it past with flying colors.Thank you for trying to help with my situation,thanks again.
I have the same issue - when it’s connected to my Mac there’s a warning that Slot B is Missing. But all tests by the WD app and Disk Utility seem to be fine.
Did you find a solution?
Hi Andy,yes i did find the solution you have to uninstall WD Drive Utility and re-install it again that should solve your problems, good luck Andy.
Thanks, Raulis. I’ve reinstalled and it seems to work so far. I appreciate your help.
