I have just purchased and used My Passport external portable drive. I have backed up my computer to it. When I go to “safely eject hardwar” I see drive G - called WD Unlocker in bold and drive H - My Passport greyed out. I try to eject Drive G and an error occured while ejecting CD drive G WD unlocker. What is happening here?
Welcome to the Community.
I’d recommend safely ejecting your WD Passport using the WD Quickview icon. It’s installed alongside WD SmartWare.
http://www.wdc.com/wdproducts/wdsmartwareupdate/wdsmartware.asp?id=wdfMyPassport&os=win
I am not using WD software at all. I use Acronis for my backups so have only installed the security where I can password protect the drive
thank you. I have just installed the smartware, but do think it extremely odd that I should have to use this rather than the usual method of removing hardware!
