I am a new (very non-technical) user. My Passport is fresh out of the box and doing its first (full) back-up. There is a dialog screen “WD App Manager Notifications” open, but no way to see the status…files copied / time remaining etc. How do I get some kind of status window / screen to see where I am in the process?
You’ll be able to see the backup status depending on the backup program you are using. Take a look at the link below:
https://support.wdc.com/knowledgebase/answer.aspx?ID=1717&lang=en
