My passport for Mac P/N WDBZYL0020BSL is used on my MBP with OS version 12.0.1. I make backups with Time Machine. Today this failed with the text that writing was not possible and I had to make a copy and reformat the disk. That failed with the Apple disk program with the note that the disk could not be deactivated. I downloaded the WD utilities. The diagnoses was OK and the quickest was OK. Reformatting however failed again. Does anybody here have an idea about this?
Might be time for a Mac friendly NAS unit and then migrate to the NAS
Thanks for your reply. Any suggestion for a Mac friendly NAS unit?
The following worked for me in Mac Monterrey
- Reboot to Recovery Mode by hitting the power button then holding down CMND R.
- Open Disk Utility from main screen when in Recovery Mode
- Highlight the external drive
- Click on Edit at the top.
- Click on Erase
- Erase the drive
- Click Edit again
- Click Delete APFS Volume (or whatever format your disk is in)
- Select file format Mac Journaled
- Name the drive
- Reformat the drive
- Restart the computer
Thanks Brian, I did manage to format the drive but now I can only make back-ups with Time Machine. When I want to add another map to that drive it forbids that. Before these troubles I could make back-ups and add whatever I wanted. Any idea what might be wrong?
