When I connect My Passport 1 Terra-Byte External Drive, It does not initialize in the Console Management Window and it does not show in My Computer as well as Windows Explorer.I have also tried updating its Drivers and it still hasn’t improved, any suggestions ?
I recommend you try some basic troubleshooting:
1- Disconnect the drive from the computer and restart the computer.
2- If the computer is a desktop, connect it on the back USB port (directly to the PC, not through a hub).
3- Make sure you hear the connection sound windows makes when recognizes a USB device.
4- Go to "Disk Management” to verify if the drive shows up there.
If the drive shows up in Disk Management but it is not seen on Computer, then it means the partition is corrupted and you will have to format it in order to use it again. Please note that formatting the drive will delete all data stored on it.
Hello Dalitso_Phiri,
I suggest you to also go through this blog Hard Drive Fixes: How to Recover Data from An Uninitialized Hard Drive? if you want to recover data from not initialized hard drive. Thanks!!
