I’m with a lot of problems with My Passport Essential SE (1TB P/N: WDBABM0010BBK-00) and the WD SmartWare Software.
After the initial install of the drivers and WD SmartWare things were going OK until I decided to set a password for the drive, I did continued to use it with no problems but I disconnect the drive and later as I plugged it again the WD SmartWare asked for the password and I’m sure I was using the right one, the hint was the one I used but it kept not accepting the password, I disconnect and connect to try again but it did no t work, since I had nothing very important on the drive and I have the backup of the files I went to the option to erase all data, after that the drive was shows as “Not blocked” by WD SmartWare.
I did not configured another password and I tough it was over, but as I disconnect and plugged it again it asked me for the password to unblock the drive, the old hint text was there too, I tried but ended up at the erase all data again, this time I set another password and another hint text disconnect the unit, when I connect back I got the screen asking me for the password to unblock, the new hint text is there but the new password is not recognized, I erase all data again and this time I set new password and them removed it (Remove security), the WD SmartWare tells me the drive is not blocked but as I disconnect and plugged it again it asked me for the password to unblock the drive, the last hint text was there.
I also tried to run a unlock.exe file that is visible by Windows Explorer (WD SmartWare) and got a mesage that says the the unity has been unblocked but it was not.
I removed and the reinstalled the WD SmartWare Software, I had to reinstall the drivers also. It kept asking me for the password to unblock and showing the last hint text I did.
After a few more attempts erasing all data I tried to put a new password but I was unable to do it, I did all the steps but when I click Update Security Settings nothing happens, the strange thing is that if disconnect the unit then I connect back in the screen for entering the password the hint text is updated but I’m unable to unblock with the password I had “updated”.
I also tried the Drive Erase unit on Settings, it tells me that all data has been erased and I should create a new password in Security, if I don’t the drive remains “blocked” although is shown to me as “not blocked” by WD SmartWare but I’m unable to unable to actually update the password it since the program seams to do nothing except update the “hint” text.
I tried to update the WD SmartWare software the the page was out three days ago and I just posted the problem for the support.
Today I did managed to download the update file an run it. I followed the instructions on the support page but after I rebooted the computer what happened was that the WD SmartWare was removed from my computer, I tried to reinstall from the previous backup that I had but the file is now corrupted, the drive is blocked, I was able to reinstall the drivers from the WD SmartWare F: disk but I cannot access the files to reinstall WD SmartWare, the unit is blocked. I did not find the complete WD SmartWare to download.
Any ideas besides returning the drive to WD?
Thanks.
