Just bought My Passport and was expecting to be able to sink Outlook emails as I can with Dmailer on a much older WD device. Cant see any options for synching Outlook though? Any suggestion
A suggestion:
I’m not familiar with Outlook, but I assume the emails are stored somewhere on your C: drive. Possibly under Program Files or Program Files (X86) or Program Data. If you can search and find these files you can tell WD Backup to include them in one separate Backup Plan. Then if you need to find them use WD Backup Restore to recover the original locations. Would not Outlook then display them for you?
Cliff
