details here
i plug it to computer and computer makes the sound that always make when u plug a usb then i go to my computer and i can’t see it igo to disk management and is not there but it shows up under device manager and it says that device is working properly and i used the wd data lifeguard diagnostic and it shows up the but its says is not available and i run a quick test and says test complete successfully with green check mark thats why im comfuse whats going on here please help!
Test Option: | EXTENDED TEST |
Model Number: | WD My Passport 0740 |
Unit Serial Number: | [Deleted] |
Firmware Number: | 1003 |
Capacity: | 0.00 GB |
SMART Status: | Not Available |
Test Result: | PASS |
Test Time: | 12:33:52, January 06, 2013 |
