My Passport 500GB is not working
I have WD passport 500GB. I have a problem connecting it with my Windows. When I connect, Computer appears to be “NOT RESPONDING”. It hangs everytime I connect, and thus doesn’t get detected. As soon as I remove the cable computer starts woring properly. I don’t understand what is the problem.
I checked in Disk Management, and same thing happened —  NOT RESPONDING… It just hanged…
Please help.
Thanks…
and My Passport Model is WDBACY5000ABK-01…
I recommend that you try it on another computer and if possible with another USB cable. If the Issue persists then ir means the drive is not working anymore.
Hey there… I have checked it on another computer…still not responding… I’ll check it with another USB cable, hope it helps…
Thanks anyway…
i have the same problem with my passport ultra 1tb.
in some pc work and in other not… any solution
