My product ID is WDBEZW0020.
I have a problem like WD External Hard Drive not detected in PC but works fine on mobile OTG
But the difference with my problem is that my hard drive is not available on my popular computer unless I insert it into the computer before starting it and after I safely remove it, I can not read it anymore.
I ended up using it after the issue. I correctly use the “Safely Remove Hardware”
I think I can not replace a computer for a hard disk.
Thanks for every reply.
My pas-sport 2t can not work on my computer, but can be used on other computers
How is the drive showing under disk management? Could be a conflict or a drivers issue.
