# My Live Book Duo not accessible + blinking blue light
**URL:** <https://forums.sandisk.com/t/my-live-book-duo-not-accessible-blinking-blue-light/299721>\
**Category:** External SSD for Windows\
**Created:** [July 10, 2018, 10:36pm UTC](https://forums.sandisk.com/t/my-live-book-duo-not-accessible-blinking-blue-light/299721 "2018-07-10T22:36:45Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![CMB\_1](https://avatars.discourse-cdn.com/v4/letter/c/7ea924/32.png) [@CMB\_1](https://forums.sandisk.com/u/CMB_1)\
**Post date:** [July 10, 2018, 10:36pm UTC](https://forums.sandisk.com/t/my-live-book-duo-not-accessible-blinking-blue-light/299721/1 "2018-07-10T22:36:45Z")
</div>
After several years with no problems, my My Live Book duo has become not accessible, and cannot be found by Windows Explorer or applications (WD Backup, iTunes, Sonos).
It now has a flashing blue LED on the front. Both LEDs on the network port on the back are unlit.
I have tried replacing the network cable from the router to the drive, connecting it directly to the PC, restarting it and resetting it.
It had been flashing blue for about a week before trying the above. Two days later it is still flashing blue.
Any ideas? I have asked WD Technical Support but have received no response, so any help would be gratefully received.
**Author:** ![asp73](https://avatars.discourse-cdn.com/v4/letter/a/958977/32.png) [@asp73](https://forums.sandisk.com/u/asp73)\
**Post date:** [July 14, 2018, 8:22pm UTC](https://forums.sandisk.com/t/my-live-book-duo-not-accessible-blinking-blue-light/299721/2 "2018-07-14T20:22:23Z")
</div>
As both LEDs on the network port on the back are unlit, issue may be with the ethernet cable or network port may be open. You should try to check with another ethernet cable or with another router with internet access.
