my fuze don't work anymore ?
okay, so one day i was listening to my fuze, turn it off, and then it wouldn’t turn back on, and it hasn’t worked since then.
i called about it and they told me some stuff to do.
like plugging it into a different computer, but i haven’t have the chance to yet.
but i wanted to know if anyone else was having this problem and how you solved it. (if you did)
and also, how do you reset it, i forgot how the guy told me how to do it.
I would agree try plugging it in to another PC or if nothing else a different USB  port (Try the back if you normally use the front) . To reset push the on off switch up and hold it for 15-20 seconds.
