My etern hd isnt working anymore
i got a wd 3200hm1u-00 etern hd
i did always worked
but now suddenly it isnt there anymore on my comp
the light is burning from the hd
but i cant find it anymore in my comp
the only thing my pc sees is a initio default controller
can some1 help me ?
now i have downloaded a driver/program from the wd site
but doesnt file delete my files from my hd ?
this link i used http://support.wdc.com/product/download.asp?groupid=110&sid=34&lang=en
can i use this program so my hd will work again
there are many files on it i dont want to lose
Jvrz
Usually when the initio default controller shows there is a problem on the circuit board. If the drive is still in warranty contact WD.
Joe
