I keep getting a message saying that there has been an unsuccessful backup because of an I/O problem? I have tried changing the USB port and the cable connection, but still the same problem. An suggestions would be appreciated
Are you able to copy files manually into the elements? You can also try using another USB cable or connecting the elements to another PC to see if the same problem happen again.
