My drive was formatted for mac but i want to use it on a PC now
My Drive was formatted for mac, I dont not mind losing all my files, I just want to use it on my PC. It comes up with the WD Smartware, but not the drive itself. I tried reading some posts and ended up deleting th drive in disk managment but then could not find it to format it again. Can someone tell me just how to reset the thing complelty on my PC for my PC?
See if this helps http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3865
Joe
You can use  Mac Drive to access the drive as is without formatting. Also you can convert the partition to Windows, that way you don’t have to reformat and erase the data. As a last resort you can format the drive with the instructions on the link provided by Joe S above.
