My document files dissapeared
Good morning, I have replaced my Win 7 OS with the Win 8.1. In the external drive, I have found My Music, My Pictures, My Videos everything went well restoring them on the PC hardrive. The problem I have is that although the Document folder is there on the external drive, it contains but one file which is for PaintShop Pro, all my OpenOffice files are not there. I notice before opening the file on the WD Book that enables me to find the saved files, files that have a lock on them are these past saved files? So, my question is what happened to my OpenOffice files?
Thank you for your help
Best regards
Guy
Hello berguy100, welcome to the WD Community. What backup software did you used to backup your files?
Hello, I used the WD Smartware that came with the external drive… Sure hope you can help, by the way, as I did not format the hardrive, it has been suggested that I would then have a Windows.old file, I do not.
regards
Guy
To further any available suggestion.
Hello, OK, I installed Windows 8.1 a week ago and everything went well until I found that all my « MyFiles » had dissapeared, not too happy about that but…
I posted a request to see if anyone had any idea where all my word, excel, PDF etc went, I guess everybody was just as puzzled as I am.
OK, moving right along, OK, I lost everything in the MyDocuments file life moves on. I had a suggestion that I could find a file called windows.old, nope not there and it was not hidden.
I am using the program supplied by Western Digital for the back ups. I now formatted the hard rive again using the software the My Book came with and upon backing up all my goodies don’t I see the MyDocuments from the computers hard drive showing 4.4 gigs??? OK, I am a little excepted that maybe just maybe my files where miraculously saved. Let the back up begin, after 1 hour or so, I created a file on my desktop and tried uploading the MyDocuments from the WD Book to the file I just created, once completed it showed only 2.10 mg. I am sending some print screens for you to look at in hopes that someone can tell me what going on. Initially before upgrading to win 8 I thought all my files where indeed there only to find out that was not the fact. If, I may ask, is it that the back program is the cause of my problems? Please, please, is there someone who can give me a straight answer?
Truly best regards to the person who can help.
Hello, Have you tried manually going in to the My Book and look for the files into the .swstor folder?
Actually, that is where I found my files when I upgraded from win 7 to 8. As I have stated I lost all mydocument files first time around therefore I should not have anything in MyDocuments, yet, when backing up at it’s finish My Book was showing me 3 gigs???
Guy
Can anyone tell me what exactly the MY Book is storing in the My Document folder?
