my clip starts only when connected to power outlet or computer
i am using windows xp sp2
i updated to the latest firmware
my clip start only when connected to a power
if it stops then i have to again connect to power outlet for my clip to “ON”
Please help me
thanks …
Possibly the broken battery wire issue.
Thanks
can we fix this overselves.There is no service center in my region
thanks in advance
You would need to open the Clip and reconnect the wire to the battery.  There has been discussion here on this–you may want to try a search (box at above left).
