All my songs are properly tagged (IDv 2.3) and CHKDSK comes up with nothing, however when I put songs on my SD card after it fills up around 3GB (the card is 32GB) it starts putting files in the UNKNOWN folder. They are not playable also, the Player skips over them as if they were corrupted. It’s like my SD card says it’s 32GB, but in reality it’s only 2-3 GB. Attaching a picture of my CHKDSK aswell, can anyone explain ‘‘allocation units’’ to me? Thanks in advance.
If H2testw likes it, then Format in the unit. (Under Settings/System Settings) and try to reload. That will erase all your added content–but it’s not working anyway, right?
Here’s an explanation of allocation units, but Sansas generally format to FAT32 so you can ignore it anyway.
Otherwise the only reason the unit shows Unknown is that it doesn’t see or can’t read what’s in the tag fields–Album, Artist, etc. Have you looked at the tags in mp3tag? ID3v2.1 won’t be read–and I know you said they are ID3v2.3, but doublecheck.
Under Tools/Options/Tags/Mpeg you can set mptag’s Write default to ID3v2.3 ISO-8859-1, which the Sansa likes. ISO-8859-1 is Windows text encoding. Highlight an album’s worth and Save them, and transfer them over, and see if the unit can read them.
