My Book Thunderbolt DUO Amber light problem
Hi everyone, just my first post here. Some days ago when i was travelling in USA i bought a 4.0TB My Book Thunderbolt DUO for my late 2016 macmini. I cannot use it yet because it has some problems.
The first time i want to use it i connect via thunderbolt cable (the inluded one) and powered up. The HDD starts normally with a white light at front, but 10-15 sec later the white light turns amber and the internal fan accelerates more, unlinking the HDD from my mac, i cannot access when the amber light is on.
I tried replacing the thunderbolt cable and connector but no success.
Anyone had the same problem? I researched quite a lot on googl but no success.
Thanks,
Regards,
According to user’s manual page #4 a steady amber light means there is a fan failure or over-/under-temperature condition.
I recommend you contact WD support for assistance with this.
https://support.wdc.com/support/case.aspx?lang=en
