My Book Status Light
The light stays on in standby mode hours after the pc is shut down. Is there a way to fix that? Will the unit overheat?
Can you please share the model number of your drive? The unit should go off if the computer is off.
Is the external drive connected to a wall power outlet?
Model WDBFJK0020HBK-0A
Yes, the unit is connected to house electric.
Thank you.
