50% of the time when I try to access the drive from any computers, it would prompt that the network drive is unavailable.
I can only access it after I switch off and on the power to My Book Live.
Green light is always there.
Ok, now it’s not even showing the green light at the Ethernet port.
Hello, did you find a solution? I’m having the same problem if I conect my notebook through wireless, if I connect through cable (as the NAS) it usually works…**bleep**
Thank you
