My Book Essential 500GB
Hi Folks,
Ive mislaid the power unit so can someone tell me what the polarity of the centre pin ie is pin 12v + or 12v - as I have a number of 12v power units but some have centre 12V + & others have 12v -.
Thanks
Jaguar240
This may be different depending of the My Book version you have. To verify this you may contact WD tech support with your model number.
Must of the drives I have form WD are center positive.
I will be good for you to provide the model number of the drive you have.
Maybe this will help you sort things out http://wdc.custhelp.com/app/answers/detail/a_id/1378/session/L3RpbWUvMTMyMDE3MTc3OS9zaWQvak9TMVcxSWs%3D
Joe
Thanks for replies. The model number is  WD5000H 1U - 00.
