not being recognized on your dvbt media player may be a compatibility issue. check with that manufacturer to see if they suppor usb 3.0. also have you tried using just the usb 2.0 cable to connect to the media player?
I should try 2.0 cable for media player. (I didn’t know that exist such a cable for little port on MB3.0)
Question still is: why MB doesn’t ‘downgrade’ speed to 2.0 automatically like it does on 2.0 comp ports?
express card…
Do you mean native driver for excard or special WD driver which comes with MB3.0 bundled with desktop excard?
(cos some users state that that driver don’t work with laptop excard)
Well, I don’t know if I installed right native driver:
after I connected my excard, xp automaticaly installed one of the bunch of drivers from bundled CD.
It’s Asmedia ASM104x USB 3.0 Host controller driver. With that driver excard reads 2.0 devices, if I uninstall it, excard is dead. (don’t know if it is right driver). Another problem is that laptop cant boot with excard inserted!
