# My Book Duo - 8TB amber light Big Sur
**URL:** <https://forums.sandisk.com/t/my-book-duo-8tb-amber-light-big-sur/254546>\
**Category:** External SSD for macOS\
**Created:** [June 16, 2021, 9:05am UTC](https://forums.sandisk.com/t/my-book-duo-8tb-amber-light-big-sur/254546 "2021-06-16T09:05:46Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![riverfate](https://avatars.discourse-cdn.com/v4/letter/r/258eb7/32.png) [@riverfate](https://forums.sandisk.com/u/riverfate)\
**Post date:** [June 16, 2021, 9:05am UTC](https://forums.sandisk.com/t/my-book-duo-8tb-amber-light-big-sur/254546/1 "2021-06-16T09:05:46Z")
</div>
Hi, looking for help.
My Book Duo, 8TB, Raid 1 configuration. Amber light, WD Utilities showing RAID status degraded as only one drive working. Drive 1 and Drive 2 status are both showing online. Do I need a new disc (and if so, what do I type into Amazon to find one!) and which one do I replace?
Big thank you in advance
David
**Author:** ![jebusx](https://avatars.discourse-cdn.com/v4/letter/j/b4bc9f/32.png) [@jebusx](https://forums.sandisk.com/u/jebusx)\
**Post date:** [June 16, 2021, 3:52pm UTC](https://forums.sandisk.com/t/my-book-duo-8tb-amber-light-big-sur/254546/2 "2021-06-16T15:52:26Z")
</div>
You can try to rebuild the RAID first. If one of the disk is bad, it should have a solid red on that disk LED.
**Post date:** [June 16, 2021, 4:30pm UTC](https://forums.sandisk.com/t/my-book-duo-8tb-amber-light-big-sur/254546/3 "2021-06-16T16:30:59Z")
</div>
Thank you, really appreciate the help. The drives are in a my book duo enclosure and so you cannot see an led for either. I thought I would be clever and remove one of the drives and see if I could still access the data. After I had tried both drives individually, they both worked on their own, I put them both back in the enclosure and now the Mac does not see them, either in finder of disc manager. I assume I have messed up the Raid configuration and will have to rebuild to see them again, but at least I was able to access the data on each.
