My book 4 tb is no longer reconized
My external drive my book 4tb is suddenly no longer reconized due to a fault of the drive. How can i fix it and if not how can i get the dat of it?
You could refer to the following link: Cannot Find My WD Drive on Windows or macOS
There could be various reasons for your external hard drive to become unresponsive or undetected. Well, one has to keep backup of his/her data so that if there is any data loss situation or anything bad happens to their storage device at least they had a backup of the files but when your drive got corrupted and you also don’t keep a backup of your critical data in that case data recovery is the only option.
You can try the below options to resolve the issue:
  • Run CHKDSK
  • Use an Antivirus & Anti-Malware tool
  • Re-install the drivers
You can also check out the below blog to know the solution for your issue: https://www.stellarinfo.com/blog/how-to-fix-not-responding-hard-drive/
Hope this will help.
