My book 2tb usb 3.0 crazy beahiviour
This drive was working fine, i changed my mother board, using same os from same disc, it wont be accessible. The hard drive is visible in both disk managment and “printers and devices”, but not in “my computer”. Downloaded driver, ed smart, no luck. I use with no problem a seagate one.
The funniest thing, i connect this wd hd to a laptop with windows xp. and it does work. Any ideas? thx
If the drive is seen on “Disk Management” then you can try changing the drive letter, also on the lower part of the Disk Management window, look for the disk and make sure it is “online”. If it is showing as “offline” then Right click on the disk in the area that says  Offline , and select  Online
