I put an album on my new Fuze, and then when I tried to delete it, it was still there. When I plug it in to my computer it says that the album isn’t there, but when I unplug it and play my music, there it is. Anyone know what’s happening here?
–Panda
Does it play or does it just show up in the list?
For a listing only: In MSC mode, delete mtable.sys , which is the database. It will rebuild when you disconnect.
If it does play, maybe you transferred it in a different mode from the one you usually use. Switch in Settings/USB mode from MTP to MSC (or the other way around) and see if your computer detects it in the other mode. Then delete it again.
Similar problem - no answer. I loaded a lot of jazz on my Fuze, plays fine. The albums appear on Windows Explorer and WMPlayer. Then I updated the firmware. Music still there on the Fuze but Explorer and Player don’t show them and I can’t delete using my computer. I loaded a few more albums and they show up fine. I deleted and restored drivers but that didn’t help. This is on both computers (XP and Vista). Any ideas anyone?
Message Edited by MrPete on 05-22-2009 08:21 AM
