i don’t really know if it is normal wat my player does when i rate a song. For example … i rate a song 5 stars press the button in the middle to apply the rating … then it kinda freezes ( the music continues playing) and after 30 - 60 seconds i can controll the player again :S
is that normal?
Thanks if anyone can help me
No, that isn’t normal
First of check that you have the newest firmware, next format and restore your music. it should work after that
