Hello everyone. I have just bought a Sansa Clip Zip to replace my old ipod classic which exploded.
With my ipod there wtasn’t much option but to use itunes, but I don’t think itunes will work with my clip zip. What do people use for their music management with their clip zip? I have seen a few people mention media monkey, but is that the best option?
In my opinion, the best music managing program is none at all. It’s not rocket science to drag & drop (or copy) files from your computer to your player. Most people with any computer experience at all move and/or copy files all the time. Music fies are no different.
I agree, but make sure you set to MSC mode using clip setup menu. Repeat if you do a firmware update which will change the setting.
if u use the MSC connection then u can sync with ur music library using a software called
always sync .
u can define folder to sync on ur PC and on ur ZIP and sync.
it supports 2 way sync and 1 way. and the option to propogate deletions on the synced side.
meaning, if u downloaded a song on ur PC and placed it in ur music library. u can plug ur ZIP and sync the new files/folders to it.
the same image of folders and files will be copied to the player.
also, lets say u have downloaded on another PC copied to ur player and then came home. u can sync from ur player to ur library on the PC.
works wonderfully, its free and saves alot of pain if u keep ur library fresh with new stuff
hope this helps
