Can you nake separate music folders on the fuse? I went to the help section and they say it is possible, but from the Folders option under the music menu. The only options I get are: artist, albums, songs genres, and playlists. I cannot find a folder option. What am I doing wrong?
The Fuze+ does not have “Folder view”, the old Fuze does. Hopefully Folder view/navagation will be added in one of the future firmware updates. You can request it as a future feature at this Thread.
A number of us have requested folder view, more request may help to get it considered. Fingers crossed : )
Thanks. I will be returning mine!!!
I may return mine too. I bought mine to use for work. downloaded my music the way I needed to play it and it messed up the whole list. Anyone know how I can get it to load in my folder in the order I need?
Although it might be tedious to create depending on the number of songs, a playlist would probably be your best option until they implement music folders.
