really would like to see MPC/MusePack support, MPC decodes easier then even MP3’s so it should make for even better batt life, also the quility of the audio is better per bitrate
if somebody can add MPC support to the fuze that would RULE, I use vorbis now, but its my 2nd favorite codec, MPC being the one I like the most.
When it’s ready, Rockbox will give you MusePack support on your Fuze.
I am not confident it will show up in the official firmware as it’s not a big codec and they would support those first.
Of course you can try Rockbox as it is now, which in my opinion is pretty much finished. Some people won’t try it until it is on the list of supported players though.
