I have file on several internal hard drives. (I.e.; C, G, H) Can I create a backup to one My Book Duo? Will the software create a separate folder for each internal drive? Sorry, I’m using WD SmartWare.
Regards
Regards
What software are you using to backup with?
WD SmartWare
Have you read through the User Manual? Also, see the SmartWare Help tab>Backup.
