MTP - language in italian
I like to connect the player in mtp mode, hoping to avoid autorun virusses, but all the popup messages and context menus are in italian…
Is there a way to change this? “Nuova cartella” is not to bad, but I have had some quite long messages that I have had to guess…
Thanks in advance for any clues…
Are you talking the player’s menu, or on your computer (Windows)?
Either way, the USB mode selected would not have anything to do with this. Sounds like you need to need the Language preferences/settings.
