hey, i asked this in the mediamonkey forums but didn’t get an answer. maybe someone here has seen it, too…
i connect via MTP mode and have fallen in love with MM’s ease-of-transfer via the SEND TO option. in MTP mode, the fuze pops up as a device in the main tree node and is the first option when right-clicking and selecting SEND TO (i usually send full albums, not playlists). i recently picked up a cheap 2GB micro sd card to expand capacity but the micro sd which cannot be recognized in MTP, only MSC mode. no biggie, right? i changed the connection mode and load MM. here’s where it gets weird: MM seems to only recognize one “drive” in the main tree node, either the fuze or the micro sd card. and what drive is “sees” seems to be random. starting MM, i will randomly get the fuze (as G:) or the micro sd (as H:) in the main tree node. going through the My Computer node allows me to see both (since windows does) and right clicking choosing the path SEND TO->FOLDER (COPY) allows me to select which ever drive isn’t in the main tree node during that start. but that’s an extra step, and i need to be extra careful not to select FOLDER (MOVE). lazy? sure, but i’ve got 2 questions:
- can MM be set to recognize both in the main tree node, such that both are available via SEND TO, without having to path through the folder selection?
- what’s up with the randomness? even if the answer to #1 is no, i’d prefer if MM always recognized the fuze in the main tree node. i’d survive going through the FOLDER (COPY) path if i needed to drop something in the micro sd card, but that isn’t what’s going on.
